2 members (J Lucas, Erniegp),
78
Mod | | | Forums66 Topics128,054 Posts1,055,780 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 144 | I want to replace my 216 in my '53 3600 with a 235. Someone told me to look for one with hydraulic lifters because they were more quiet. Patrick's says that there are no good replacement lifters for the hydraulics and to get a solid or get a kit to change the hydraulics to solids. Which is best? At this stage, I may as well do the right thing. Thanks John | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I'd keep the hydraulic once set they tend to stay set, there quiet,and very dependable , and You're not going to get any more HP unless You get a custom cam then You're going to have to change the carb to match and the exhaust.There are alot of original hyd.lifters out there if one ever goes bad.
Pete | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Not sure why Patrick's would say that except that there is so much inferior off shore auto products sold these days. I run hydraulics in my '55 235. Hydraulic 235's were mostly associated with automatic transmission cars and that's what my engine came out of. Search around for a good condition engine here on the Stovebolt or over at Inliners. www.inliners.org You can always switch out to solids with a new cam later.
Drew
| | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Remember that hydraulics and solids will work in an engine bored for the oil to reach them, but hydraulics will not work in an engine that is not bored for hydraulics. My personal choice is hydraulic lifters. They are a more modern approach to an engine for street use.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | I like the sound of the valves myself. Kinda sounds like a sewing machine running. | | | | | Joined: Mar 2009 Posts: 124 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 124 | the machine shop i use ordered me a set of hydrolic lifters that were made in brazil. when i brought up the same issue of cheep lifters the machinist assured me they were of a high quality nand from a company that he uses regularly for parts on other motors as well. i dont remember the brand but they look well made. the machinist i mentioned is reputable.
my point? i think there are sources for quality hydrolic lifters out there. | | | | | Joined: May 2010 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 144 | Thanks to all for the info. Now if I can just find a nice 235 near Western North Carolina. I have no idea of how to get one shipped. John | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Call some junk yards in you're area there were LOTS of 235s built and for many years in cars and trucks,try and find one from a car with a power glide trans,it will be full pressure oil and hyd. lifters get rid of the power glide and bolt up You're 216 bell housing,clutch and trans and You're off and running ,You'll also have some water pump changing to do they sell the pump for this.
Pete | | | | | Joined: Apr 2009 Posts: 13 Apprentice | | Apprentice Joined: Apr 2009 Posts: 13 | Might mention that the 235 engines with hydraulic lifters came in powerglide equipped cars beginning in 1953, but a 235 engine from a later year would probably be better.
Larry
Tarheel
| | | | | Joined: Apr 2010 Posts: 283 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 283 | Also be aware that the cam lobe profile is different for solids/hyd. If solids are used with hyd cam the clearances must be set much tighter (probably .002-.003) to get any quietness at all and to prevent increased seat wear and even valve head breaking off. If hyd are used with solid cam the valve timing will be crazy and the idle/low end performance may suffer because of the solid lifter cam having a ramp to take up the normal clearance slowly.
Bob Taylor
| | | | | Joined: May 2010 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 144 | If a motor is not presently running,as in a junk yard, how can I tell if it is a safe bet to purchase it to have it rebuilt? I would hate to get a cracked block or ruined insides, etc. Any shopping ideas or simple field tests? Thanks John | | | | | Joined: Apr 2009 Posts: 164 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 164 | I check by pulling plugs, check the oil, pull valve cover, see if I can turn it over by hand. | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | All of the above,when You check the oil make sure there is no anti freeze in it ,also some junk yards will give you're money back on a cracked block just make a deal with them and get it in writing ,as far as worn insides unless the engine has just been rebuilt no one knows whats good or bad in an engine even if it was running last week.
Pete | | | | | Joined: Sep 2001 Posts: 26 New Guy | | New Guy Joined: Sep 2001 Posts: 26 | Look for a 56 or later 235 if you can. Bigger intake valves, as I remember, maybe other improvements. | | |
