3 members (55shaker, MOTOXFAMILY, SNOYL), 178 guests, and 4 robots.
Topics128,268
Posts1,058,379
Members48,485
#648430 05/21/2010 4:33 PM
I am a little worried about the steering in the truck. I talked with my Grandpa about it back when he gave it to me.. and was having a chat with my uncle and cousin about it a couple weekends ago.... what everyone has mentioned is that at about 35 the truck does a 90 degree turn to the right... straight into the ditch. My uncle changed axles... did the perches on the suspension... but it still does it.
Any thoughts? I have to lift it up to see the condition of the tie rods which I am sure I will have to rebuild... but what about power steering? I think I am going to drop a 235 in it as I want the option to be able to drive it daily... so I want to keep somewhat stock....
I'd make sure the tires are good and the wheels not bent.
hmmmm, could be the wheels.... hopefully I can get them straightened if they are bad!
Any thoughts on the power steering? =)
The power steering kits on the market are designed for the 1/2-ton trucks so they don't quite match up for the 1-ton. You'll be doing at least some of your own design work to convert.
Check the rear end,rt hub and brakes.somethin locking up could cause this. I know it sounds crazy but I've seen it before...Mike
Moderated by  Dusty53
