1 members (3800GUY),
89
0
Mod | | | Forums66 Topics128,189 Posts1,057,336 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 79 | Hi All, Found me a hydrovac at NAPA.My 48 Loadmaster had a broken rear spring and I found one of those too in a local yard .Problem is when I replaced it I also found worn bushings pins etc... on my truck. Can anyone recommend a source for these items?As always thanks for your responses.
Resp. JMH | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I found some of them at Rock Auto and others by searching brass bushings in Google. I believe if you check sizes you'll find 3/4-ton and larger all use the same rear spring stuff with some spacers when the springs are different sizes.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jan 2008 Posts: 20 New Guy | | New Guy Joined: Jan 2008 Posts: 20 | When I redid the front springs on my 37 Chevy pickup I went to the local springworks (called Sacramento Spring) and they had all the bronze bushings on the shelf. He said that many of the new big trucks still use the same bushings because they work so well. And he could make you any replacement spring that you needed for a reasonable price. I would look for a local spring shop where you live, the older the better.
Jaysin | | |
