9 members (Peggy M, Otto Skorzeny, tclederman, Shade Baby, DadsFirstPickup, FAST55, Bucker, wilbur53, 1 invisible),
78
Mod | | | Forums66 Topics128,159 Posts1,056,900 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | I'm talking about the two piece hold down springs that hold the brake shoes to the backer plate, not the spring that connects the shoes to eachother. My '48's rear had one of these springs come loose and get ground up by the shoe. I bought some replacements from one of the large vendors, but can't get the thing in. I think it's too short. Anyone else have trouble with these? | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Assuming you are using the correct tool the nail/brad may be too short. Your local Napa auto parts store should have a selection of different sizes. Maybe remove the one that didn't break for comparison. | | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | Thanks, Tim, but those springs are entirely different from those on my '48. Mine has kind of a cone shaped spring, with a key shaped pin that goes down the middle. It has a hook on the end that's supposed to hook up to a small bracket on the backer plate. Here's what they look like: brake hold down spring assembly | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Those are interesting looking, Tom.
| | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | Those are springs for Huck brakes. I was able to install new ones on mine using a pair of pliers and a little effort. New ones are available from Jim Carter. The ones in the Classic Truck Parts link are for the later Bendix brakes.
Harold Wilson 41 Chevy 3/4 Ton
| | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | Harold, the ones for the Bendix brakes were in the link Tim Lederman posted. I bought the ones from my link. Three of us have attempted to install them, with no luck. | | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | Ya gotta hold the Tongue in just the right position.....  a pair of needle nose vise grips and a strong hand helps too.... | | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | ...and don't forget the cursing. | | | | | Joined: Aug 2005 Posts: 341 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 341 | I got the same spring kit that Tim showed which is for 2 wheels but it only came with 2 horseshoe shaped clips. Anyone know where those clips install?
Allan ----- 1951 GMC 1/2-ton Two 1953 Chevy 3100 5-window | | |
