8 members (55shaker, MickeyP, Bill Hanlon, 3B, Gdads51, Ridgeback, Gray_Ghost, 32Fordpuchoptop),
112
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,118 Posts1,056,304 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 17 New Guy | | New Guy Joined: Sep 2009 Posts: 17 | I have a lead on a 1961 without a title. I want to understand if the 4 speed and rear end will get me a good cruising speed (~70mph) in my 52. Is it an easy swap?
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | 2 speed, 3 speed, 4 speed all have the same final drive gear: 1 to 1, and have no effect on top speed or any speed in high gear. Only overdrive, or an overdrive transmission (T5, 700-R4) does this. The axle will only help if it has a numerically lower ratio than yours, such as 3.55 vs. your 4.11, etc. What is it? | | | | | Joined: Sep 2009 Posts: 17 New Guy | | New Guy Joined: Sep 2009 Posts: 17 | pretty sure a 52 has 4.1:1. I was hoping the 61 had 3.55:1.
If correct, what is the cruising speed?
| | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | The '61 will be 3.90:1 if it's a half ton and it came with a manual transmission. | | | | | Joined: Sep 2009 Posts: 17 New Guy | | New Guy Joined: Sep 2009 Posts: 17 | not much better then? I an get it cheap I think. It has been close to a fire, broken glass and blistered paint. But if I can't use the parts then just another project. | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | The '61 center section is a direct bolt in to your '52 housing. (if they are both half ton) Which will get you a little bit faster gear and an open driveshaft as well. You will need to weld the spring pivots also. The gear change will gain you about 3 mph at 2500 rpm. | | | | | Joined: Sep 2009 Posts: 17 New Guy | | New Guy Joined: Sep 2009 Posts: 17 | I will go look at the truck and see/hear it run. | | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | A 61 with a 3:90 rear axle will do 70 miles an hour, but not very comfortably. 60 miles an hour is a pretty good cruising speed for mine, but I usually have to go faster so I don`t get in the way. | | |
