6 members (Otto Skorzeny, R&S 51 GMC, KEVINSKI, Bill Hanlon, Swami29, Phak1), 100 guests, and 0 robots.
Topics128,125
Posts1,056,339
Members48,440
#647829 05/19/2010 6:20 PM
I have a lead on a 1961 without a title. I want to understand if the 4 speed and rear end will get me a good cruising speed (~70mph) in my 52. Is it an easy swap?
2 speed, 3 speed, 4 speed all have the same final drive gear: 1 to 1, and have no effect on top speed or any speed in high gear. Only overdrive, or an overdrive transmission (T5, 700-R4) does this.
The axle will only help if it has a numerically lower ratio than yours, such as 3.55 vs. your 4.11, etc.
What is it?
pretty sure a 52 has 4.1:1. I was hoping the 61 had 3.55:1.
If correct, what is the cruising speed?
The '61 will be 3.90:1 if it's a half ton and it came with a manual transmission.
Steve
'49 3800
'52 3600
'57 3100
not much better then? I an get it cheap I think. It has been close to a fire, broken glass and blistered paint. But if I can't use the parts then just another project.
The '61 center section is a direct bolt in to your '52 housing.
(if they are both half ton)
Which will get you a little bit faster gear and an open driveshaft as well. You will need to weld the spring pivots also.
The gear change will gain you about 3 mph at 2500 rpm.
Steve
'49 3800
'52 3600
'57 3100
I will go look at the truck and see/hear it run.
A 61 with a 3:90 rear axle will do 70 miles an hour, but not very comfortably. 60 miles an hour is a pretty good cruising speed for mine, but I usually have to go faster so I don`t get in the way.
