1 members (Hotrod Lincoln), 130 guests, and 2 robots.
Topics128,143
Posts1,056,494
Members48,442
#647095 05/17/2010 2:47 AM
where is the best anchor (attaching) points on my straight 6 to remove engine? thanks for the help out there!
H Online: Content
Remove a couple of cylinder head bolts, and make brackets from angle iron to bolt onto the engine, using those head bolts. I use bolts diagonally opposite each other, front and rear. Then bolt your lift chain to holes drilled in the angle iron. Be sure not to bend pushrods or other components with the lift chain.
thanks Jerry, i got it out w/ no damage to anything but i knew there had to be a better way to replace it!! I hope there will be room on back left head bolt for a peice of angle and not hit pushrods or firewall. wish me luck....some days i need all i can get!!
1 Offline
I use this setup on an Eastwood leveler. The bolts are 1/2-12 x 5, the spacers are old 1/2 drive sockets. Using the head bolt torque sequence: the bolts with the spacers go in the #7 and #8 holes (on the intake side)and the bolts with the 1/2 SAE washers go in the #9 and #11 holes (on the distributor side). Very easy to tilt or level the engine with this rig.
http://s858.photobucket.com/albums/...&current=P1010151-1.jpg&newest=1
Joe D.
1 Offline
Also, turn the "L" brackets with the short legs to the inside so everything clears the rockers.
Joe D.
thanks Jerry and Joe, this helps a ton....i'm gonna order a Eastwood leveler right now. Take care.
