| | | Forums66 Topics128,095 Posts1,056,480 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 66 | where is the best anchor (attaching) points on my straight 6 to remove engine? thanks for the help out there! | | | | | Joined: Feb 2004 Posts: 29,831 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,831 | Remove a couple of cylinder head bolts, and make brackets from angle iron to bolt onto the engine, using those head bolts. I use bolts diagonally opposite each other, front and rear. Then bolt your lift chain to holes drilled in the angle iron. Be sure not to bend pushrods or other components with the lift chain. Jerry
| | | | | Joined: May 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 66 | thanks Jerry, i got it out w/ no damage to anything but i knew there had to be a better way to replace it!! I hope there will be room on back left head bolt for a peice of angle and not hit pushrods or firewall. wish me luck....some days i need all i can get!! | | | | | Joined: Aug 2005 Posts: 94 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 94 | I use this setup on an Eastwood leveler. The bolts are 1/2-12 x 5, the spacers are old 1/2 drive sockets. Using the head bolt torque sequence: the bolts with the spacers go in the #7 and #8 holes (on the intake side)and the bolts with the 1/2 SAE washers go in the #9 and #11 holes (on the distributor side). Very easy to tilt or level the engine with this rig. http://s858.photobucket.com/albums/...¤t=P1010151-1.jpg&newest=1Joe D. | | | | | Joined: Aug 2005 Posts: 94 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 94 | Also, turn the "L" brackets with the short legs to the inside so everything clears the rockers.
Joe D. | | | | | Joined: May 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 66 | thanks Jerry and Joe, this helps a ton....i'm gonna order a Eastwood leveler right now. Take care. | | |
