2 members (Gazz, Otto Skorzeny),
101
Mod | | | Forums66 Topics128,096 Posts1,056,482 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 42 New Guy | | New Guy Joined: May 2010 Posts: 42 | From a distance my tires look in good shape, but closer inspection reveals lots of dry cracks, etc... I have no idea how safe they are, so to err on the safe side I called a local tire store and to replace my tires the cost would be: -$169.99/tire (6 total) -$80 freight -$15/tire for mounting
For a grand total out the door of ~$1287.
Definitely pricey. Is this my best (/only) option or does anyone have other solutions? I could fix up lots of little things here and there for that much, but the truck isn't much good without tires.
I need to get a spare wheel as well, but I will look for one at a swap meet / online.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Depends on what you are going to do with the truck.If you are doing some heavy hauling &/or going a long way you would want to go with 6 new ones. If it's just a toy you could put the best ones on the rear duals & just replace the front ones. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I've had good luck searching used tire shops, may take a while but I've saved some money. Also put wanted ad for your size tires on craig's list. Best of luck | | | | | Joined: May 2010 Posts: 42 New Guy | | New Guy Joined: May 2010 Posts: 42 | Thanks guys. Not doing any heavy hauling, but more than a play truck. My philosophy with this truck is to use it as an around the house work truck but want the flexibility to be able to travel 100 miles or so as well with a light or medium load (few hundred pounds). Mostly for transporting veggies, compost, lumber, maybe some gravel, etc...
I think I will watch craigslist and the used tire shops. If I run into a problem before then, I'll have to bite the bullet. | | | | | Joined: Feb 2004 Posts: 29,831 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,831 | At one time, a lot of the the 1-ton rated van type bread trucks were equipped with 19.5" tubeless tires and tapered-bead rims. They were a direct replacement for the 18" tube type tires, same overall height but with a slightly shorter sidewall. If there's a bakery in your area that's been in business for a long time, check to see if they've got some leftover spare wheels and tires! Jerry
