1 members (Ponchogl),
163
Mod | | | Forums66 Topics128,101 Posts1,056,182 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#64683 08/22/2006 3:30 AM | Joined: Jul 2006 Posts: 58 Member | | Member Joined: Jul 2006 Posts: 58 | Well, I mentioned on here a while ago about going to a 2 barrel for my inline 6 through the use of a Summit Racing adapter. And the results... I got the motor to run. I drove it around and right away I could tell, it definetly had power. I only pushed in the accelerator a slight bit and it just opened up and asked to race. I was feeling really good about it. The only negative side was that I could not get the darn thing to idle steady. It wanted to run too lean or too rich. It was really bad in gear and at a complete stop and liekd to overlaod on fuel. This is with a brand new Rochester 2bbl by the way. Anyway, that's it. The one barrel is back on and actually isn't too bad. It turns out the float levels on it were WAY wrong and that's why it kept overloading on gas. Now I'm not afraid to floor the motha'. :lol: But it's still slow. :whine: I know some had their doubts on speed imrpovement, but I felt it. It felt like it was giving the motor all the gas it could and would have no trouble supplying more. Do y'understand? It felt like it had more muscle behind it basically. As for the 2bbl, I returned it to Kragen and got credit back for a used one from the scrap yard. As for the adapter... it makes a lovely paper weight. Anybody who'd like to shed some light on the subject of why my 2bbl wouldn't idle right, I'm willing to read lengthy essays. It's not like I have a V8 yet or anything. The 6 pack is still under the hood. And the adapter is right here next to me (holding down papers). :gi: Here's a picture by the way. Hope you like my Kustom throttle linkage [img] http://i27.photobucket.com/albums/c157/DiscoDanny/Truck/IMG_0141.jpg[/img]
1967 Chevy truck "The Hurricane"
WARNING: This suspect has a tendency to jerry-rig.
"My engine ain't fast, but I pulled a tree trunk out of the ground once."
#64684 08/22/2006 4:37 AM | Joined: Mar 2004 Posts: 154 Member | | Member Joined: Mar 2004 Posts: 154 | good to hear the results!
to me, seat of the pants feeling is alot more important that numbers on a dyno...i mean, who cares if you make X amount of horse power, if you can't feel it or notice it?
sorry. i have a thing against numbers now. just started a College Alg. course, and realized i remember NOTHING about math. ew.
but, -ahem-, i digress.
congrats on your experiment!
i know nothing of why it wouldn't idle. ask the experts. lol
.later days. .sam. 1969 K20 , with a '67 front clip. fleetside. 292, 3x1 offy, headers. sm465 4spd. getting put back together, almost ready for paint. doing it all myself. 19 and lovin' it. "proper" is so over-rated. .later days. .sam.
#64685 08/22/2006 12:32 PM | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | I ran a 2 barrel rodchester on a 261 years ago with modified stock manifold with good luck. I used a 2 barrel from a 283 and had to rejet the main jets smaller. At the time I was doing this smaller jets couldn't be had so filled the old jets and redrilled them to the proper size. Also the old 261 had the head shaved for more compression and had a mild cam that might have helped with the extra fuel air mixture. Sounds tome like you may have had leaks or to big of a carb. | | |
#64686 08/22/2006 5:37 PM | Joined: Jul 2006 Posts: 58 Member | | Member Joined: Jul 2006 Posts: 58 | Leaks were my thoughts as well but we had every vacuum entry or exit on the carburetor sealed or leading to it's "proper place" and sealed tight there. My only other guess is that there was a gap somewhere between the spacer and adapter or carburetor and spacer.
#64687 08/23/2006 1:59 AM | Joined: Jul 2006 Posts: 49 Member | | Member Joined: Jul 2006 Posts: 49 | some carbs have holes on the bottom for vacumn.i changed a gasket on a 235 and ran into that problem.i had to notch the gasket.
64 c10 89 rs 62 econoline 50 ford coupe
#64688 08/23/2006 5:09 AM | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | I tried a few different 2G's and had idle problems with all of them. The one that I got to run the best (best in this case - the least crappy), I actually tried to make it a ported vaccuum using a Dremel. It didn't work. If you do a search, I posted a bunch about this a couple years ago. About idle and vaccuum and timing. Glad the 1 bbl is workin' for ya. -David | | |
#64689 08/23/2006 1:04 PM | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Carburetors pull fuel from the idle wells because of air velocity across a pickup point creating a negative pressure in the wells. The pressure in the bowl then pushes the fuel into the throttle area.
For best results, when migrating any O.E. carb from one application to a different application, do not exceed 3 percent CID differential. 3 percent of 235 CID is about 7 CID. So, WITH A NORMAL INTAKE SYSTEM (NO ADAPTER), you should expect to see decent results using a two barrel from an O.E engine of displacement 228 CID through 242 CID.
The eddy currents created by the short adapter will mess up the velocity anyway, so it really doesn't matter which carb doesn't work with the adapter.
If you modified the intake manifold for normal two barrel application, the Carter from a 232 CID A.M.C. would work well on a 235, but not with the adapter.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
#64690 08/23/2006 1:38 PM | Joined: Feb 2006 Posts: 19 Apprentice | | Apprentice Joined: Feb 2006 Posts: 19 | Has anyone ever thought about removing the top of the stock intake on a mill and reconfiguring the intake to accept a different carb ? | | |
#64691 08/24/2006 7:22 AM | Joined: Jul 2006 Posts: 58 Member | | Member Joined: Jul 2006 Posts: 58 | Well, it's a little more complicated then just "changing it to fit". There's drilling and welding and I pretty much suck at both I'm going V8 unless for some reason a brand new/rebuilt I6 just suddenly appears in the garage. That doesn't mean I won't still interact on the site or throw away the old 250. I'm gonna store it and later on learn how to rebuild it and then tune it up and all that jazz.
#64692 08/24/2006 9:33 AM | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | John thats what I did on the old 261 manifold. I opened the top of the manifold where the carb mounted cut out the tee in the heater box. Made a plate to close off the bottem of the heater box and made a plate for the top of the manifold for the carb. I did this 30 some years ago with a hack saw and a torch with a milling machine I think you could do it with out doing any welding. | | |
#64693 08/24/2006 12:12 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Carbking's points are to be taken into consideration no matter what carb is used,even hi performance carbs must be matched to the manufacturers recomendations for best results. I posted earlier on this same subject how I milled off the top of a stock 261 intake to adapt a 2 barrel carb with excellent results a few years ago.Yes, the job required a little welding,and yes the cast intake can be MIG welded,but the modification were done with common hand tools,hand held grinder,files ,drills and taps. | | |
#64694 08/25/2006 8:11 PM | Joined: Jul 2006 Posts: 58 Member | | Member Joined: Jul 2006 Posts: 58 | Hmm... well I suppose just for the Hell of it I could do some measureing.
But hey, you know the integrated head inline 6's? I hear that they're garbage but they came stock with a 2bbl carburetor. Do you think it'd be logical to assume that one could cut it from the head at the 3 "arms" and weld on new ends from a removeable intake manifold? This having a two barrel, BOLT-ON intake manifold?
#64695 10/09/2006 5:13 AM | Joined: Dec 2002 Posts: 3,441 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,441 | how did it work out.. Rusty Rod is watching with eyes wide open!!! next target!! :p
#64696 10/15/2006 5:32 AM | Joined: Apr 2006 Posts: 4 Junior Member | | Junior Member Joined: Apr 2006 Posts: 4 | the carb on the integrated head engines is this weird two stage thing that any junkyard guy will laugh at you for trying to run.I had mine apart about 6 times trying to figure out wht the idle circut wasnt working.finally gave up last week and im going with a 2g.working on an adapter in tech right now that should be done monday(cnc machines are great)and then im gonna open the intake up a bit to make it flow a bit better. should work out okay. | | |
