5 members (Uncles51, 55shaker, Woodcmiami, Stovebolt48, joe apple), 65 guests, and 3 robots.
Topics128,021
Posts1,055,351
Members48,420
#646300 05/14/2010 2:57 AM
jmh
Offline
Hi folks,
I have a question for all.My Loadmaster 2 ton has Hydrovac brakes.The things simply will not work without a total replace or rebuild.Can I remove the Hydrovac and just go with regular brakes(new master cylinder,lines etc...)I know I will have a decrease in brake capacity but I will not be pulling excessive loads.Also the two speed axle is not working.Can I swap out the old axle with a late model with electric two speed? Thanks for any and all responses.
Old bolts are the best bolts!
JMH
jmh #646360 05/14/2010 5:51 AM
3B Offline
Hy jmh, welcome, please remember to tell us what year your truck is when you ask questions. If you were to leave the hydrovac out of your brake system, you would have no decrease in brake capacity, you would have to generate more pressure with your foot however, The hydrovac can be rebuilt, and you can find them rebuilt on "E" bay among others, as for the rear axle, yes you can swap it for one with an electic two speed, but why don't you determine what is wrong with the one you have and repair that?
3B #646523 05/14/2010 9:10 PM
jmh
Offline
Thanks for the info.Can you reccomend a source for the Hydrovac rebuild. My truck is a 1948 model.
JMH
jmh #646526 05/14/2010 9:34 PM
Riding in the Passing Lane
You can't hardly stop one of those without the booster.
1972 Chevy c10 Cheyenne Super
jmh
Offline
Cant stop ? Thats what I was afraid of.Again can anyone tell me where I can send the unit for rebuild? Also the 2speed valve located in the cab where is the low range located ,to the right or left? The bracket nor handle is not marked.Please excuse my ignorance on this stuff as it is kinda new to me.
JMH
jmh #646624 05/15/2010 4:01 AM
3B Offline
Hy jmh, you could contact your local Napa or whoever your local nationaly affiliated auto parts supplier is, or if you have a truck repair shop in your area you could call them and ask them who they would suggest. On one of my 46s low speed is to the right on the dash control, but that is a different style of controller than a 48 would use, seeing as how you need vacuum to shift into high range you should always park in low.
3B #646694 05/15/2010 12:22 PM
Jim Carter lists rebuilt hydrovacs on his website at the price I hope that includes a later refundable core charge. I believe 48 bigtrucks found hydrovac unit on the shelf at carquest a while back. There are also offering rebuild services in hemmings motor news.
kb3csw #646754 05/15/2010 6:28 PM
I had the one for my 1954 done a few months ago. It cost about half of what a rebuilt from an auto parts store would have been.
Karp's Brake Service
Excellent service on getting it done also.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
