4 members (Steelonsteel, ShopRag, 78buckshot, TooMany2count), 61 guests, and 1 robot.
Topics128,035
Posts1,055,552
#64636 08/21/2006 1:33 PM
Apprentice
Apprentice
I need some advice. I am rebuilding a 67 283. The valves look good in it and I was wondering if i need to spend the $250 to have hardened valve seats installed. The truck was run regularly as far as I know up to about 5 years ago. Any help would be appreciated.
MACZ
#64637 08/21/2006 1:36 PM
When I had my head redone the valve seats only cost $60. All the head work combined (valves, guides, seals, springs, flux, valve job, etc...) cost about $250 total.
How many miles on your engine before you decided to rebuild it? If you are rebuilding why wouldn't you do the head?
#64638 08/21/2006 2:53 PM
Riding in the Passing Lane
If you are rebuilding the engine you must be doing a valve job also. You should have the hard seats put in but I don,t think it should cost that much.
1972 Chevy c10 Cheyenne Super
#64639 08/21/2006 4:14 PM
Apprentice
Apprentice
I called around here and the valve job will cost $200. Seats are about $11 each and they want $150 to install the seats. The engine only has 100k on it but sat for several years so for insurance I was going to re-ring it only to find rust pitting in #7 from the exhaust valve being open all the time it sat.
MACZ
#64640 08/21/2006 5:08 PM
Ex Hall Monitor
Ex Hall Monitor
I had a 70 Harley that I rode for years without putting hardened seats in it & never had a problem. I now have a 38 216 without hardened seats & have had no problem. I suppose since you're rebuilding anyway it wouldn't be a bad idea to change the seats but I don't think it's necessary. I remember reading a thread in another forum (VCCA I think) on this subject & the concensus was that unless you're planning on running the engine hard (racing, pulling heavy loads long distances, etc.), hardened seats are unnecessary.
#64641 08/21/2006 6:00 PM
Apprentice
Apprentice
Thanks for the info Tiny. I will be using the truck to cruz and to drive back and forth to work so I think I will do without the seats.
MACZ
#64642 08/22/2006 4:16 PM
I don't think you will need them unless you plan on a lot of hard use. Its the heat with lack of lubricant that eats away the seat. The lead in fuel was the lubricant. Replace only those that are worn out.
My thoughts are, if you replace all 16, you now have 16 parts that could come loose! To replace these, the machine shop will cut out a area around the seat, then the new seat is pressed into place, no mechanical bond. The next step is to finish machining the seat to spec's. One of the draw backs is if they seat is not matched to the port throat, they leave a step which really messes with the air flow on the intake side. Replacement seats are great way to get a worn head back to full compression, but for long term parade style driving, totally unnessecary! Joe
#64643 08/22/2006 5:31 PM
Apprentice
Apprentice
Thanks Joe.
I haven't pulled the heads apart yet, but what I can see, I should not need and valves. The machine shops are pushing the seats, but I think I will do without them.
MACZ
#64644 08/22/2006 11:39 PM
I'm still running soft seats in my trailer pulling 1-ton across the desert on 115 deg. days. Yuma - San Diego = 4500 ft. elevation change both ways, hill is in between. Always figured when it broke I'd fix it. It's a '63 B.B.,haven't had to yet. Doug
