| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#64614 08/21/2006 12:05 AM | Joined: Aug 2006 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 98 | First off I'ld like to say that I'm new here and so far,have found a wealth of info for myself.
OK,here's my question.I'm rebuilding a 1960 LB stepside.I've got 2 trucks for this,one runs,the other is a donor.The chassis I'm rebuilding has what I beleive is an overload spring that goes over the top of the rearend.My driver truck doesn't have this.Was this an option,or did they all have and the one on my driver just get tossed sometime? | | |
#64615 08/21/2006 12:27 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Is it a spring or is it an anti-roll bar? | | |
#64616 08/21/2006 1:14 AM | Joined: Aug 2006 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 98 | It's a spring.Looks like a leaf spring to be exact. | | |
#64617 08/21/2006 2:39 AM | Joined: Jul 2006 Posts: 49 Member | | Member Joined: Jul 2006 Posts: 49 | if its a half leaf spring that hits the end of the trailing arm only when its loaded,it was an option.i have a set.
64 c10 89 rs 62 econoline 50 ford coupe
#64618 08/21/2006 2:42 AM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Picture of a set on a 46..... Is this what you have? Yep, probably an option or add-on to get a little more weight on the truck. I took mine off, but they had done a lot of work over the years. | | |
#64619 08/21/2006 10:40 PM | Joined: Aug 2006 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 98 | Actually 46 In Progress mine is differant than your pic.Mine runs from side to side over the rearend.Also has a brace that runs under the rearend to help keep it in place.Guess I should of taken a pic of it before I took it off yesterday.
nc c10 ,fan it hits the bottom of the frame,not the trailing arms. | | |
#64620 08/22/2006 1:34 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Sound like an add on by PO.
Bill Burmeister | | |
