4 members (Maybellene, klhansen, 2 invisible), 87 guests, and 3 robots.
Topics128,211
Posts1,057,468
Members48,471
The trim on the side of my '63 is dull. I have tried to use metal cleaner that works on my bikes, dremel buffing wheels, all to no avail. Hints? I tried 2000 grit, no go. Thanks.
Pete
1963 Chevy C-10 Fleetside
1970 C-30 Dump Truck
2025 Silverado High Country 2500 Diesel
2012 Indian Chief Vintage serial #002 motorcycle
1946 Indian Chief, 1947 Indian Chief w/sidecar,2014 Indian Chieftain, 2015 Indian Scout
The aluminum trim is anodized, which cannot be re-polished. There is no bringing back the brightness without first removing the dulled anodizing. You can use a chemical remover for this or carefully sand it off. after that, it can be polished like a mirror. I don't think it's something you should do with the trim on the truck.
They say oven cleaner will remove anodizing, be sure to remove the trim first! From there, standard metal polishing will brighten it up.
The previous owner did one side,and not the other. It looks odd too me. I am appreciative for your comments guys.
Last edited by 63 C-10 Carolina Fleetside; 05/03/2010 2:43 AM. Reason: misspelled words
Simply removing the anodize and polishing isn't the answer, it needs to be protected with a new anodize otherwise it will dull in short order.
Eastwood sells a product that is supposed to remove the anodize LINK
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
I wouldn't listen to "they" too much. Most all oven cleaners are highly caustic and will slowly dissolve aluminum.
Harold Wilson
41 Chevy 3/4 Ton
Czechman, reckon I will have to remove the trim? Or can I wipe this stuff on with a rag? I have placed an order. I have seen people use oven cleaner to remove stuff from exhaust pipes of another kind of vehicle with less wheels than a truck of which I happen to own several of, but was told I couldn't mention them on this forum by a moderator or risk being censored as this is a truck forum. I always thought oven cleaner to caustic and if you accidently hit the paint you were in deep dodo, this product seems to be water based.Thanks everyone for their comments. The previous owner said he did it with a certain grit sandpaper. I have tried 2000 grit to no avail.
Oven cleaner is a great product for removing paint. I'd call Eastwood and ask if you have to remove the trim, or it may have instructions that answer your question.
Woody
Door Art Collection
I did the anodized aluminum grill over for my 74 Econoline..I used a stripper from Caswell but I believe Lye will work as well.
I polished the stripped grille and side pieces..it came out super. I have just been paste waxing it and it is holding up great.
looooong process but worth it
Lye is another term for sodium hydroxide or sometimes potassium hydroxide both of which are as strong or stronger than typical oven cleaners. Both will pit and discolor aluminum and dissolve it if given a little time.
Harold Wilson
41 Chevy 3/4 Ton
the Caswell stripper I used had a buffering agent in it. It worked well with no pitting.
Another source of sodium hydroxide - which by the way when added to a bucket of water makes a great paint remover, is septic tank main line cleaner from the hardware store. I had to give about $10 for a gallon.
I have a pair of fog light buckets that will come out in bare metal and ready to paint in the morning. If it has rust and paint, add a battery charger and it will pull the rust off. see electrolysis.
