3 members (2-Ton, 52Carl, 1 invisible),
94
Mod | | | Forums66 Topics128,211 Posts1,057,469 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 231 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 231 | The trim on the side of my '63 is dull. I have tried to use metal cleaner that works on my bikes, dremel buffing wheels, all to no avail. Hints? I tried 2000 grit, no go. Thanks. Pete 1963 Chevy C-10 Fleetside 1970 C-30 Dump Truck 2025 Silverado High Country 2500 Diesel 2012 Indian Chief Vintage serial #002 motorcycle 1946 Indian Chief, 1947 Indian Chief w/sidecar,2014 Indian Chieftain, 2015 Indian Scout | | | | | Joined: Apr 2008 Posts: 95 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 95 | The aluminum trim is anodized, which cannot be re-polished. There is no bringing back the brightness without first removing the dulled anodizing. You can use a chemical remover for this or carefully sand it off. after that, it can be polished like a mirror. I don't think it's something you should do with the trim on the truck. | | | | | Joined: Feb 2009 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 137 | They say oven cleaner will remove anodizing, be sure to remove the trim first! From there, standard metal polishing will brighten it up. | | | | | Joined: Nov 2006 Posts: 231 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 231 | The previous owner did one side,and not the other. It looks odd too me. I am appreciative for your comments guys.
Last edited by 63 C-10 Carolina Fleetside; 05/03/2010 2:43 AM. Reason: misspelled words
1963 Chevy C-10 Fleetside 1970 C-30 Dump Truck 2025 Silverado High Country 2500 Diesel 2012 Indian Chief Vintage serial #002 motorcycle 1946 Indian Chief, 1947 Indian Chief w/sidecar,2014 Indian Chieftain, 2015 Indian Scout | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Simply removing the anodize and polishing isn't the answer, it needs to be protected with a new anodize otherwise it will dull in short order. Eastwood sells a product that is supposed to remove the anodize LINK | | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | I wouldn't listen to "they" too much. Most all oven cleaners are highly caustic and will slowly dissolve aluminum.
Harold Wilson 41 Chevy 3/4 Ton
| | | | | Joined: Nov 2006 Posts: 231 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 231 | Czechman, reckon I will have to remove the trim? Or can I wipe this stuff on with a rag? I have placed an order. I have seen people use oven cleaner to remove stuff from exhaust pipes of another kind of vehicle with less wheels than a truck of which I happen to own several of, but was told I couldn't mention them on this forum by a moderator or risk being censored as this is a truck forum. I always thought oven cleaner to caustic and if you accidently hit the paint you were in deep dodo, this product seems to be water based.Thanks everyone for their comments. The previous owner said he did it with a certain grit sandpaper. I have tried 2000 grit to no avail. 1963 Chevy C-10 Fleetside 1970 C-30 Dump Truck 2025 Silverado High Country 2500 Diesel 2012 Indian Chief Vintage serial #002 motorcycle 1946 Indian Chief, 1947 Indian Chief w/sidecar,2014 Indian Chieftain, 2015 Indian Scout | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Oven cleaner is a great product for removing paint. I'd call Eastwood and ask if you have to remove the trim, or it may have instructions that answer your question. | | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | I did the anodized aluminum grill over for my 74 Econoline..I used a stripper from Caswell but I believe Lye will work as well. I polished the stripped grille and side pieces..it came out super. I have just been paste waxing it and it is holding up great. looooong process but worth it | | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | Lye is another term for sodium hydroxide or sometimes potassium hydroxide both of which are as strong or stronger than typical oven cleaners. Both will pit and discolor aluminum and dissolve it if given a little time.
| | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | the Caswell stripper I used had a buffering agent in it. It worked well with no pitting. | | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | Another source of sodium hydroxide - which by the way when added to a bucket of water makes a great paint remover, is septic tank main line cleaner from the hardware store. I had to give about $10 for a gallon.
I have a pair of fog light buckets that will come out in bare metal and ready to paint in the morning. If it has rust and paint, add a battery charger and it will pull the rust off. see electrolysis. | | |
