1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | The current 500 edelbrock on my 292 e/w a clifford intake is crimping Caroline's pocket book. http://s67.photobucket.com/albums/h298/1951otter/?action=view¤t=22A-1.jpghttp://s67.photobucket.com/albums/h298/1951otter/?action=view¤t=23A-1.jpgShe's got [the engine that is] a mild rv cam. Is there a modern single barrel carb I can swap to w/ a plate to cover the four barrel to a single of what model carb? thx guys
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Modern carb? Aren't all modern motors EFI?
Rather than replace the carb you might look at an economy oriented tune-up. A well set up four-barrel should deliver better economy than most single barrel carbs if your driving for economy.
Try adding a vacuum gauge and driving for max vacuum.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I'm with Steve, try retuning. One problem you will have going to a single carb is that intake. No real good or efficient way to adapt a single, best bet would be a different manifold. Another thing you might look at, a smaller 4 bbl, like a Holley 390.
Bill Burmeister | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | also IMO, 292's are gas hogs no matter whose foot's in'em  Bill | | | | | Joined: Feb 2000 Posts: 5,210 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,210 | Heres just what you need!
http://www.speedwaymotors.com/Vintage-2-Barrel-Carb-Adapter,5025.html
Figure out some progressive linkage, and you are good to go.
Joe | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | Heres just what you need!
Humor, I hope? | | |
