0 members (), 140 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
The current 500 edelbrock on my 292 e/w a clifford intake is crimping Caroline's pocket book.
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=22A-1.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=23A-1.jpg
She's got [the engine that is] a mild rv cam. Is there a modern single barrel carb I can swap to w/ a plate to cover
the four barrel to a single of what model carb?
thx guys
Jim & Caroline
Modern carb? Aren't all modern motors EFI?
Rather than replace the carb you might look at an economy oriented tune-up. A well set up four-barrel should deliver better economy than most single barrel carbs if your driving for economy.
Try adding a vacuum gauge and driving for max vacuum.
I'm with Steve, try retuning. One problem you will have going to a single carb is that intake. No real good or efficient way to adapt a single, best bet would be a different manifold.
Another thing you might look at, a smaller 4 bbl, like a Holley 390.
Bill Burmeister
also IMO, 292's are gas hogs no matter whose foot's in'em wink
Heres just what you need!
http://www.speedwaymotors.com/Vintage-2-Barrel-Carb-Adapter,5025.html
Figure out some progressive linkage, and you are good to go.
Joe
Humor, I hope?
