Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Stovebolt48, cmayna), 180 guests, and 5 robots.
Topics128,283
Posts1,058,504
Members48,490
Apprentice
Apprentice
Trying to install new pan and timing cover on 1969 pickup with 350 crate motor. I've got the pan loose but I'm having trouble getting the oil pan out from under the motor. I am not able to get it past the flywheel (which is exposed). Any tricks to this? I'm afraid that the tranny is the problem. I've tried jacking up areas but this didn't help. I didn't think this would be so difficult.
Also, I've got the front end down to the pully. Any tricks to getting this off easily?
I gave up golf for this!
Riding in the Passing Lane
You need to disconnect the front engine mounts & raise the front of the engine. Make shure the counter weight on number 1 cyl. is up in the engine. The pully bolts to the front of the damper with 3 bolts & the damper bolt. You must use a puller that uses the taped holes in the damper. Screw the balancer bolt partway in to push against. Do not pull from the outer edges of the damper.
1972 Chevy c10 Cheyenne Super
Apprentice
Apprentice
Thanks Wrenchbender! got the timing cover off. Now how do I determine if the counterbalance is up?
It is a large counterweight on the front of the crank just inside the oil pan. If it is in the down possition the pan hangs up on it makeing it impossible to get the pan off with the engine in the truck. If it is in the down possition turn the engine till it is positioned up in the upper part.
Apprentice
Apprentice
Thanks Wrench got it all done today and nothing leaks currently. Appreciate all your help
Quote
You did the right thing.
