1 members (Hotrod Lincoln), 57 guests, and 1 robot.
Topics128,094
Posts1,056,066
Members48,433
#645717 05/12/2010 12:29 PM
I've been thinking of how best to go about painting the interior of my '51 and not being a professional painter it looks pretty daunting with all the different things that need interior color. I'm using a factory match 2K Omni paint which is metallic and has to be carefully applied to get an even finish. I think the best way to go would be in two stages:
Stage one would be to mask everything off to protect from overspray and only paint the dash and rear valance (I believe that's what the metal surrounding the rear window is called). That way I can get inside the cab and sweep the gun the entire width of these parts rather than trying to lean in and do half at a time.
Stage two would be to mask off the dash and valance and shoot everything else.
If anyone is willing to share their experience painting the interior of their cab I'd be very appreciative.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Woody, Valance ?, You mean the back of the cab. Are the doors on the truck and your going to paint the jams?
I know what your up against, to paint everything at the same time means too much overspray usually.
Then there's all that masking to paint just parts which I have done to achieve the result I'm after.
The only thing that comes into play using a metallic is the application.
You just have to try and duplicate the sane way of applying the paint every time. A little wetter, a little dryer will render a different look.
I think I would be using your approach to situation because you don't want to have to deal with what the over spray will ruin.
Dan
Remember your freedom - US Veterans provided it.
101st Screaming Eagles
I used a common JGA DeVilbiss spray gun, spraying the brown metallic, spraying the complete interior with no over-spray problems...I also used clear too...No metallic sag...I did have an exhaust fan running...You do not need hvlp...Just cut Your air pressure down...Bill B.
1952 Chevy 3104 Shortbed 5-window
Remember; Politicians and diapers both need to be changed
often, and for the same reason.....
Back in the 70s we used to call the part of the interior that surrounds the rear window a valance so that's what I call it... besides I can type that faster grin
The cab is completely gutted with no doors or anything else attached.
Woody
Door Art Collection
Did you paint the floorboards and behind the gas tank too or just the parts that required the color?
Where did you start and end?
Woody
Door Art Collection
Woody,
I think I'd paint the dash last. You want it flawless. That's is what people feel and see first. If you get overspray any place I'd say Not on the dash. You have to worry about hitting your butt on the dash painting your rear valance. I used a detail gun in tight spots on mine which may help too. My 4t6 interior was removed from the truck so I didn't have those issues. Have fun and good luck
Dan
