2 members (Bill Hanlon, 1 invisible), 131 guests, and 3 robots.
Topics128,026
Posts1,055,408
Members48,422
#64545 08/19/2006 3:26 AM
Hey y'all. I was just wondering if anyone knows if it's possible to resleeve a 235. The one I have is in rough shape, but the pistons are fine and I would like to reuse them if at all possible. :confused:
-John
'61 Apache 10
'93 Suburban
'04 Envoy (Straight Six!!!)
If it ain't loud, I ain't interested
#64546 08/19/2006 3:37 AM
Lurch,
From a machining standpoint, I would say it is possible. From a common sense standpoint, I would put it right at the bottom of the list.
If the bore is shot, the pistons are shot too!
Stuart
#64547 08/19/2006 4:09 AM
It ain't that the bore is shot, it's one of them IRWIPI deals... 'cept grandpa did the parkin'. Any ideas? Perhaps lightly honing the bores to remove any rust...
-John
'61 Apache 10
'93 Suburban
#64548 08/19/2006 5:11 AM
I would hone the cylinders and Mic them to check them out as a first step. If they don't make it have them bored and get get biger rings and pistons.
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
#64549 08/19/2006 12:57 PM
"Hey y'all. I was just wondering if anyone knows if it's possible to resleeve a 235?"
Actually no, since it never had sleeves to begin with.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#64550 08/19/2006 4:53 PM
Yes, it can be bored and sleeved to standard to reuse your pistons. But, that would probably cost a lot more than just boring and new pistons. Sleeving requires boring, honing to sleeve o/d, pressing in the sleeve, and then honing the sleeve to size. A lot more labor than just boring and honing.
If your rust isn't too deep, a glazebuster type hone with lots of oil ( I use diesel ) to keep the junk washed off might clean it up. Try one and the measure the amount removed.
