1 members (1 invisible),
105
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#64545 08/19/2006 3:26 AM | Joined: Aug 2006 Posts: 20 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 20 | Hey y'all. I was just wondering if anyone knows if it's possible to resleeve a 235. The one I have is in rough shape, but the pistons are fine and I would like to reuse them if at all possible. :confused:
-John '61 Apache 10 '93 Suburban '04 Envoy (Straight Six!!!) If it ain't loud, I ain't interested
#64546 08/19/2006 3:37 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Lurch,
From a machining standpoint, I would say it is possible. From a common sense standpoint, I would put it right at the bottom of the list.
If the bore is shot, the pistons are shot too!
Stuart | | |
#64547 08/19/2006 4:09 AM | Joined: Aug 2006 Posts: 20 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 20 | It ain't that the bore is shot, it's one of them IRWIPI deals... 'cept grandpa did the parkin'. Any ideas? Perhaps lightly honing the bores to remove any rust...
#64548 08/19/2006 5:11 AM | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | I would hone the cylinders and Mic them to check them out as a first step. If they don't make it have them bored and get get biger rings and pistons.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | |
#64549 08/19/2006 12:57 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | "Hey y'all. I was just wondering if anyone knows if it's possible to resleeve a 235?"
Actually no, since it never had sleeves to begin with. | | |
#64550 08/19/2006 4:53 PM | Joined: Jul 2003 Posts: 132 'Bolter | | 'Bolter Joined: Jul 2003 Posts: 132 | Yes, it can be bored and sleeved to standard to reuse your pistons. But, that would probably cost a lot more than just boring and new pistons. Sleeving requires boring, honing to sleeve o/d, pressing in the sleeve, and then honing the sleeve to size. A lot more labor than just boring and honing.
If your rust isn't too deep, a glazebuster type hone with lots of oil ( I use diesel ) to keep the junk washed off might clean it up. Try one and the measure the amount removed. | | |
