1 members (Woodcmiami), 72 guests, and 3 robots.
Topics128,031
Posts1,055,433
Members48,422
#645293 05/11/2010 3:41 AM
Hello,
When I start my 1941 chev with a 235 install, it idles nice at first and then within a couple seconds it quickly begins to idle at a very high RPM until I go under the hood to the carb and take the link connected to the gas pedal and full up with it and then back down. After this, it good until the next start. It sounds as it someone is pressing down on the gas pedal but no one is.
I first that it was a vacuum leak but I removed the line and cap. That didn't change it.
Anyone have any ideas?
41chevy!! #645324 05/11/2010 4:59 AM
Is it vibrating towards the carb with the engine running? Maybe re-tighten/ use a closer link on the original spring?
1959 Chevrolet 3100 Stepside Apache
"Ignorance is bliss. Here's a history book."
59 rolling iron #645891 05/12/2010 10:44 PM
If your manual throttle is connected there is a chance that it is holding the carburetor linkage on a higher idle.
Also check the surface where the idle screw rests. It should be stepped so that as the choke is closed the idle speed setting is increased (you should always depress the gas pedal when closing the choke). Most of the time the idle will not drop off of this step by pushing in (opening) the choke, you have to blip the gas pedal.
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
Kip's41 #646027 05/13/2010 5:42 AM
Disconnect the linkage from the carb and see if the problem is outside or inside. Sometimes the throttle butterfly is not centered in the bore. If this is the case give me a holler you can get in real trouble here.
retired wrench #658235 06/29/2010 3:20 AM
Excellent advice, thanks!
