3 members (52Carl, klhansen, Bill Hanlon), 334 guests, and 5 robots.
Topics128,159
Posts1,057,037
Members48,460
#6452 02/02/2005 4:06 AM
Junior Member
Junior Member
I am putting in a 261 in a 46 chevy to replace the 216. I found a 1/8 pipe plg infront of the oil out on the side of the engine. I thought it was the correct place to red the oil presure. No luck.
I ended up installing a remote oil filter and connected the oil gage there.
But where is the cort on he engine????
Ted Wilson
#6453 02/02/2005 8:51 AM
The factory oil filter equipped 261's had a fitting between the oil return line and the block that was tapped 1/8" npt for an oil pressure gauge line. It was not actually in the block itself.
Paint & Body Shop moderator
#6454 02/03/2005 4:40 AM
Junior Member
Junior Member
tHANKS THAT EXPLAINS IT.
i WILL LEAVE MINE WHERE IT IS.
Ted Wilson
