3 members (Danielbolt, bluechev, 1 invisible),
104
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,157 Posts1,056,875 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 40 Junior Member | | Junior Member Joined: Jun 2004 Posts: 40 | I am putting in a 261 in a 46 chevy to replace the 216. I found a 1/8 pipe plg infront of the oil out on the side of the engine. I thought it was the correct place to red the oil presure. No luck.
I ended up installing a remote oil filter and connected the oil gage there.
But where is the cort on he engine????
Ted Wilson
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The factory oil filter equipped 261's had a fitting between the oil return line and the block that was tapped 1/8" npt for an oil pressure gauge line. It was not actually in the block itself.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Jun 2004 Posts: 40 Junior Member | | Junior Member Joined: Jun 2004 Posts: 40 | tHANKS THAT EXPLAINS IT.
i WILL LEAVE MINE WHERE IT IS.
Ted Wilson
