| | | Forums66 Topics128,078 Posts1,055,939 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#64507 08/18/2006 3:29 PM | Joined: Jul 2006 Posts: 5 Junior Member | | Junior Member Joined: Jul 2006 Posts: 5 | My 54' 3600 has the old split rim wheels (8 lug) with 235-85R-16 tires on it. Did these split rims come on these old bolts or were these added some time ago? I know the tires were added later. Also, what kind of hubcaps/wheels could I put on these trucks for appearance especially with the large axle hub on rear? | | |
#64508 08/19/2006 2:16 AM | Joined: Jun 2006 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 49 | Yes, the 3/4 tons came standard with a two piece rim. True "split rims" are three pieces and were on the bigger trucks. I found some 16" dexter wheels at a trailer shop. Google on dexyer and you will find some places that may still have them. Dexter doesn't carry them anymore but there are still some around. I had to put clips on them but they look pretty good. Click on THE SLEEPY DRAGON link below to check them out. What you have to watch out for is back spacing. Its very short due to the tie rod ends on my truck. I am not sure if the '54 used the more modern ends. Of so, you won't have that problem. | | |
