5 members (MRMEROTH11, TrknGMC, TUTS 59, Gray_Ghost, panic), 127 guests, and 0 robots.
Topics128,068
Posts1,055,880
Members48,428
#644885 05/09/2010 10:43 PM
Y
Y Offline
Hey all, I have a 1949 chevy 3600. I added the second tail light to this truck. It has a new wiring harness(the pvc coated reproduction of the original) stock tail lights, mounts etc. The bulbs in the passenger side taillight only get a mirror like coating on them after a while, and it gets so thick that you cannot see the light coming thorugh except at little pin holes around the glass to brass area of the bulbs. It is only on the passenger side, and it does it with every set of bulbs I have tried. I have started just carrying bulbs to replace them when they get to dark.
Any ideas?
1949 Chevy 4400 Big Red
1949 Chevy 3600 Bob's Truck
1949 Chevy 3100 The Investment
1949 Chevy 3800 the Won Ton
Yelostn78 #644888 05/09/2010 11:02 PM
6v or 12v?
Bill Burmeister
LONGBOX55 #644892 05/09/2010 11:17 PM
Riding in the Passing Lane
When bulbs fog up inside its from air leaking in. If all of them are from the same box you may have got a bad bunch. There is some cheap stuff out there. If water is getting in & hitting the bulb when it is hot will cause this to happen.
Your neighbor, George
1972 Chevy c10 Cheyenne Super
Y
Y Offline
6V, Most of the bulbs are yes cheap bulbs, but I have had a hard time finding in-stock decent quality bulbs for 6v. there have been two different brands that have done this, both cheap by the looks of them.
