3 members (87GN, Gray_Ghost, 1 invisible),
119
Mod | | | Forums66 Topics128,057 Posts1,055,816 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 502 | Hey all, I have a 1949 chevy 3600. I added the second tail light to this truck. It has a new wiring harness(the pvc coated reproduction of the original) stock tail lights, mounts etc. The bulbs in the passenger side taillight only get a mirror like coating on them after a while, and it gets so thick that you cannot see the light coming thorugh except at little pin holes around the glass to brass area of the bulbs. It is only on the passenger side, and it does it with every set of bulbs I have tried. I have started just carrying bulbs to replace them when they get to dark. Any ideas? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 |
Bill Burmeister | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | When bulbs fog up inside its from air leaking in. If all of them are from the same box you may have got a bad bunch. There is some cheap stuff out there. If water is getting in & hitting the bulb when it is hot will cause this to happen.
Your neighbor, George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 502 | 6V, Most of the bulbs are yes cheap bulbs, but I have had a hard time finding in-stock decent quality bulbs for 6v. there have been two different brands that have done this, both cheap by the looks of them. | | |
