8 members (mason86, Ol'55, klhansen, Hotrod Lincoln, 32Fordpuchoptop, Ponchogl, Phak1, 1 invisible), 77 guests, and 1 robot.
Topics128,050
Posts1,055,676
#64488 08/18/2006 2:16 AM
Per Steppenwolfs great picture expose on the 55 rear pumpkin swap in his '45' and Rick Rickard's comments on swapping out his TT 3rd member for a '56' pumkin, I too have decided to go this route for an open drive line in my 46. I want to keep the original housing, axels, 6 lug wheels, brakes, etc. I will weld new saddles on, and replace the torque tube 3rd member with an open drive shaft pumpkin.
QUESTION:
WHat years are the open rear'ed pumpkins direct swaps? Have the same axel spline numbers, 10 bolt pattern, etc? Going junk yarding tommorrow and woud like the widest range of years possible to increase my chances of purchase.
Brett
cavebull
Stovebolts - so easy even a Cavebull can do it.
https://www.flickr.com/photos/dodsonbrett/collections
#64489 08/18/2006 4:46 AM
I swaped a '60 3.90 third member into my '53 rearend. I know that same axle goes up to '62. I'm not sure where it starts, but that shouldn't matter because you want to go as new as possible for a higher gear set.
Good Luck.
Real easy swap.
The more I think about it, I think they went to a 3.90 gear set in '55.2
I think thats what steppenwood put in his truck aswell.
So anywhere from '55.2- '62 should work.
And as I think about it even more, you have to go newer then '55.2 because thats when they put in the open driveline.
I think I think to much...(editx4)
#64490 08/18/2006 1:55 PM
All 1955-62 half ton will fit.
My Blog
#64491 08/19/2006 2:48 AM
^ The simple answer. (makes note)
#64492 08/19/2006 4:20 AM
ok, lets clear up some confusion for ME. I have a 55 (3.90) to put in my 52panel when I get the body off. Are you saying my current axles will also go into the 55 pumpkin without changing anything?? I was "told" I would have to change the rear end splines to fit my 52 axles. I'm about 6 weeks away from this but an answer now would help me sleep better at night.
#64493 08/19/2006 5:33 AM
I have my original 1945 axels going into my 1955 (3.90) pumpkin. It was a easy swap.
Even if the axels didn't fit into the '55 pumpkin, you can take the spider gears out of your original pumpkin and put them into the '55 pumpkin. The spider gears come out quit easy and that is what has the splines for the axel.
#64494 08/19/2006 3:20 PM
All 1/2 ton axle splines are the same from 1940-62.
My Blog
#64495 08/20/2006 4:04 AM
Thank you very much. I understand and it is what I thought. Thanks for taking the time to answer. Now I will sleep better!
