5 members (Woodcmiami, 6inarow, Bill Hanlon, 59 fleet, 1 invisible), 90 guests, and 2 robots.
Topics128,035
Posts1,055,556
#64429 08/16/2006 10:57 PM
I'm looking for a T5 to put in ' 65 C10 and was at a salvage yard when the " guy " tells me that some T5 transmissions have the bellhousing and transmission case cast as one unit and some are separate . I know I need the separate unit . Can anyone give me more info on this and what years this was done ? Thanks for all help !
" The heart of the wise inclines to the right , but the heart of the fool to the left " - Ecclesiastes 10:2
#64430 08/16/2006 11:06 PM
None that I know of. I could be wrong but I have read alot aout the T5 and never came across this. Some T5 transmissions were put in Camaro and Firebird and they had unique bell housings. The were tilted to one side, but the T5 was the same as any Chevy bolt pattern and could be seperated from the housing and used in other setups.
Bill Schickling
1940 1/2 ton, 1940 3/4 ton
My web page
#64431 08/16/2006 11:15 PM
There might be a B&W 4 speed that is cast as bellhousing and box, but the t-5s aren't that way.
#64432 08/17/2006 2:05 AM
The "guy" is right, some T-5s have the bellhousing cast along with the gear box, tell him you want the other style. The one you want will bolt up nearly the same as your old trans did, with some minor differences. Check this site for tech tips on the T-5, also go to www.Inliners.org site for more T-5 info. But, hang in there you'll love the T-5 when it's installed in your truck. best of luck.
1946 1/2-Ton Chevy
#64433 08/17/2006 9:07 PM
Riding in the Passing Lane
I,ve run into the ones that are 1 piece while looking for them. It seems they are on mid 80,s S-10s although I wasn,t shure weither they were T-5s or not. I agree with Jim I love mine.
1972 Chevy c10 Cheyenne Super
#64434 08/18/2006 2:42 AM
I just bought my T-5 today, 13-52-145, 85-86 S-10. I am am sure I will love it as well, but right now hating trying to get the adapter made. Buffalo Enterprises is out of pocket for a couple of days and the turn around is a couple of weeks. The local machine shop guys are hesitant. Have not seen it done so don't think it will work and don't seem to want to mess with it. It does not look like it will be intalled on this trip.
Anyone have the CNC program for one. It would be much easier to get then. I had to leave my original bell housing, the t-5, and a link to Steppenwolf's photo journal on the swap, so they can get me an estimate. Jeez, I can't wait to get back to the real south...and I am from here!
cavebull
Stovebolts - so easy even a Cavebull can do it.
https://www.flickr.com/photos/dodsonbrett/collections
#64435 08/18/2006 2:44 AM
cavebull
