3 members (RLB, qside, Gray_Ghost), 71 guests, and 1 robot.
Topics128,072
Posts1,055,907
Members48,429
#64424 08/16/2006 3:49 PM
Can anyone tell me, if I am removing the engine and transmission as a unit, do I have to monkey with the u-joint on a torque tube drive line? Or do I just loosten the packing nut and slide the transmission off of the splines?
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
Jed Offline
Toyvo,
Get out your tools. Fraid you got some "monkeying" to do.
Don't you mean slide the u-joint off the propeller shaft? Sure it will slip off. Completly undo the ball nut(collar)and be sure to use the 2 bolt holes specified in the shop manual and the whole thing will balance. If you weld 2- 8" long 1/2" nc bolts to 2 rings you don't even have to take the valve cover off. A search will find you the 2 holes to use.
Curt B.
You Tube
Toyvo,
I think what you describe would work; however, you would be sliding the u-joint yoke (not the transmission) off the splined end of the driveshaft.
You could do it your way, by loosening the threaded "cap" at the rear of the u-joint cover/bell, or, by removing the 4 bolts that hold the u-joint cover/bell and sliding the cover/bell back on the torque-tube.
You will need more clearance space in the front of the engine but most likely you will have the radiator, if not the grill (and hood), off the truck.
Tim
Thanks for the speedy reply guys. I will pull the 4 bolts and the install should be a little bit easier. And I have the whole front end off the truck as we intend to do paint work with the engine out. Oh and I did mean slide the yoke off the propeller shaft, I was wr---wro--wron-- mistaken.(see my signature at the bottom of this post).
