8 members (delky, val, UtahYork, Otto Skorzeny, mason86, Bill Hanlon, Woodcmiami, 1 invisible),
60
Mod | | | Forums66 Topics128,030 Posts1,055,424 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 323 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 323 | I want to use my 61 283 in my 38 is it possible to use a 350TH ? Is there an adaptor of some kind for the starter? or do I have to use a 2 speed powerglide ?
1937 Chevy 1/2 ton panel 1953 GMC 2 ton. future car hauler
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | why not use a 700r4 instead of the 350? ron | | | | | Joined: Feb 2010 Posts: 323 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 323 | I guess I could. There is still the bell housing mounted starter issue.
| | | | | Joined: Nov 2008 Posts: 137 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 137 | Lots of trans adaptors out there. Do a search. Is your motor stock? If not, I recommend a Torque convertor out of a corvette. Also some work will need to be done to the 700R4, so that you are not loading up the motor just crusing. | | | | | Joined: Feb 2010 Posts: 323 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 323 | Thanks I'll check out the adaptors any recomendations
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | you don't need an adaptor. there is a another starter that bolts up into the block, rather than into the the bellhousing. one just has to make sure that they have the correct flywheel with the corresponding nbr of teeth to go with which starter ron | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Are you sure padresag? I don't believe the 283 has the block mounts for the starter. I haven't had a 283 in a long time though. | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | all 63 and up do as I have 3 of them here. if it had the cast iron bellhousing(std trans) it bolted to the b/housing. a/powerglide, it bolted to the block. the aluminum case turboglide I presume also used a bolt to block starter from 57-61 ron | | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | I recommend a Torque convertor out of a corvette. For what it's worth, there's nothing special about a vette torque converter. Any chevy converter will work, you just have to get the right stall for your application. | | | | | Joined: Feb 2010 Posts: 323 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 323 | After closer inspection a starter will bolt up to the block.Block date is A171, 3756519 casting, FOII8D vin, that makes it a 1961.So a 700r4 should bolt right up.I haven't played with a 283 in a while either, sorry for the runaround.
| | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | Nice of you to report back, it helps us all a bit. Too many people forget to do that. | | | | | Joined: Nov 2008 Posts: 137 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 137 | I recommend a Torque convertor out of a corvette. For what it's worth, there's nothing special about a vette torque converter. Any chevy converter will work, you just have to get the right stall for your application. Exacty. Different Stalls for different vehichles and applications. There are numerous stalls available. Corvettes use a higher RPM stall.This will help get you into the "seat of the pants" launch, where as most chevy "passenger" cars you do not want that, just a nice smooth take off. | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | and he is going to launch with a stock 283? ron | | | | | Joined: Feb 2010 Posts: 323 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 323 | STOCK 283? WHAT IS THAT? I know I could get more out of a 383 but I want to keep the engine early.
| | | | | Joined: Nov 2008 Posts: 137 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 137 | and he is going to launch with a stock 283? ron You seem to underestimate what a 283 will do. Remember the 283 and 327 were the engines they had to work with back in the 50's and 60's. Built right a 283 will produce easily 340HP | | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | I am running a 283 with a TH350 in my 49 suburban. Everything bolts up. Starter bolts to the block.
Weeds | | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | I'm with Weeds. I have a '59 283 block with a TH 350 in my '49 1/2 ton. Everything, including the starter, bolted right up.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
| | | | | Joined: Apr 2010 Posts: 436 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 436 | My 63 C10 came stock with the 283, Powerglide, and 3.73 rearend. I had no problem smoking the tires.
The 283 is one of the most underrated of the small block V8's. People tend to forget that it launched many of the early Corvettes, Impalas, and ChevyII's before the advent of the 327. It even held it's own pretty well after the 327 came out.
| | | | | Joined: Mar 2010 Posts: 76 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 76 | Nothin wrong with a 283. Twisters!!!! FOrged crank stock too. | | |
