2 members (baldeagle, Ponchogl),
98
Mod | | | Forums66 Topics128,014 Posts1,055,328 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 31 Apprentice | | Apprentice Joined: Mar 2010 Posts: 31 | I was wondering, about how much the frame,drivetrain, axels,brakes and all the suspension stuff wieghs all together.pretty much everything but the fenders grill cab hood and bed.Thanks | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | | | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | I have the 'frame,drivetrain, axels,brakes and all the suspension stuff' for a '54 in my back yard, but I don't know how to weigh it. My bathroom scale only goes to 300 lbs  Interesting question, but as Gazim says, why? | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | He could start cutting it into 300 pound chunks. Just a suggestion  | | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | Might be worth a try....I do have the day off!  | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I could just barely lift my frame without anything attached to it. It seemed like the 4 speed transmission was heavier than the frame. | | | | | Joined: Jul 2008 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 176 | I measure the weight of things by how many men it takes to carry it for short distances. Chassis without the engine = 3-4 men. Frame only takes one man. Completely assembled engine, cab, and box are each two men. | | | | | Joined: Mar 2010 Posts: 31 Apprentice | | Apprentice Joined: Mar 2010 Posts: 31 | Sorry its a 1/2ton. for the reason im planning on doing a s10 swap, for more modern drivetrain and 4x4. im trying to see how much i could get if i scrap it all. the frame is pretty rusty,and engine block is cracked.so i was thinking about scraping it to get money towards the s10. and yes twotone you should cut it into 300 pound chuncks for me haha jk | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The scrap yard has scales and they know how much to pay per ton. | | | | | Joined: Mar 2010 Posts: 31 Apprentice | | Apprentice Joined: Mar 2010 Posts: 31 | yea i figured they would,but the reason i was kind of wondering was because one yard said 100$ a ton with minimum of 500pounds,and the other said they would give me 120$ regardless of weight. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Scrap steel prices are up right now. Around $400 a ton for Auto scrap, remember auto scrap is mixed so it brings much less. I would say if your scraping an AD rolling chassis with the engine and trans, with out any body panels on it, you would do well to get $100 for it. Your might be able to get a little more if you stripped of some of the parts and tried selling them one one of the forums, but then again that's a lot hassle. DG
Denny G Sandwich, IL
