5 members (Oswald, DadsFirstPickup, Hotrod Lincoln, J Lucas, 1955 1 Series), 66 guests, and 1 robot.
Topics128,047
Posts1,055,622
#643866 05/06/2010 12:56 AM
Have any of you ever sealed a cracked engine block with sodium silicate (liquid glass)?
At what concentration does the solution need to be mixed with water?
Does the engine need to be warmed prior to application?
Any other info that would be helpful...
Stovebolt Gallery
1952 Chevy 3100
1953 Chevy 4400
1965 Nova
Pics on Photobucket
H Online: Content
Waterglass isn't up to the job of sealing a block- - - - -possibly a seep leak in a radiator core, or something like that. If you clean the crack thoroughly and maybe grind it smooth for about 1/2" on each side, a product called "Marine-Tex" is about the best product I've found for crack repair, better than J-B Weld by far. If there's much pressure in the cooling system, even Marine Tex will seep after a short time. Welding or brazing is the only effective crack repair, or a process called "sewing" where overlapping threaded plugs are installed.
Block repairs are expensive and are not always reliable. If it were mine, I would start looking for another block.
1946 1/2-Ton Chevy
H Online: Content
Good info, especially the tutorial on block heating and coooling. He deliberately cracked the Caterpillar block, though, by getting it too hot in one place and letting it cool too quickly. I've brazed several cracked blocks by controlling the heating and cool-down better. Arc welding a block is very tricky, but doable.
Marine Tex is great stuff and they now make several strenghts with sixteen thousand being the lightest and they go on up but this HL said would be a temp fix. There is a pinning and welding process I have saw some place but do not know much about it. If it were me I would try and locate a used or MAYBE a new head from one of the in-liner places but that would be a long shot at best.
62Blue
Don
62Blue
62Chevy in progress
You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
