1 members (Rusty Heaps),
116
0
Mod | | | Forums66 Topics128,035 Posts1,055,564 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 69 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 69 | I need a little help. 1999 chevy 5.3 v-8 motor in 1957 pickup. Computer controlled. No engine codes have alerted. Hessitates as you push down the trottle (cable throttle), but only when cold. warms up, goes away. Happens under engine load, not in neutral. Haven't changed fuel pump or filter because it's not a constant problem. Only on a cold startup. Any ideas. | | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | Check the resistance on the coolant temperature sensor. It's a thermistor that changes resistance as the coolant warms up, and one that's out of range will not set a code, but it will cause the cold start/warmup problems you're describing. If you've still got the scanner port in the wiring harness, a scan tool will allow you to monitor the CTS performance. This is a common failure on the fuel injected engines- - - -I've seen it a lot over the past 25 years. Jerry
| | | | | Joined: Aug 2007 Posts: 69 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 69 | | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | I am with Jerry, check the CTS, also check the throttle blades for carbon build up.
| | | | | Joined: Mar 2010 Posts: 41 Apprentice | | Apprentice Joined: Mar 2010 Posts: 41 | if its not the coolent sensor check fuel pressure and filter.cold engines need more fuel.if that all check out look at the manifold air temp sensor.
55 stepside 3600 67 chevelle ss conv joe springfield,PA
