0 members (), 91 guests, and 1 robot.
Topics128,055
Posts1,055,782
#641865 04/29/2010 4:53 PM
I need a little help. 1999 chevy 5.3 v-8 motor in 1957 pickup. Computer controlled. No engine codes have alerted. Hessitates as you push down the trottle (cable throttle), but only when cold. warms up, goes away. Happens under engine load, not in neutral. Haven't changed fuel pump or filter because it's not a constant problem. Only on a cold startup. Any ideas.
57Chev #641869 04/29/2010 5:01 PM
H Online: Content
Check the resistance on the coolant temperature sensor. It's a thermistor that changes resistance as the coolant warms up, and one that's out of range will not set a code, but it will cause the cold start/warmup problems you're describing. If you've still got the scanner port in the wiring harness, a scan tool will allow you to monitor the CTS performance. This is a common failure on the fuel injected engines- - - -I've seen it a lot over the past 25 years.
Thanks. I'll try that.
57Chev #642042 04/30/2010 3:22 AM
I am with Jerry, check the CTS, also check the throttle blades for carbon build up.
Apprentice
Apprentice
if its not the coolent sensor check fuel pressure and filter.cold engines need more fuel.if that all check out look at the manifold air temp sensor.
55 stepside 3600
67 chevelle ss conv
joe
springfield,PA
