5 members (Cosmo, Otto Skorzeny, Bwana-Jim, J Lucas, Hotrod Lincoln), 98 guests, and 1 robot.
Topics128,036
Posts1,055,450
Members48,422
#643635 05/05/2010 4:13 AM
After a complete cleaning, I filled one shock with ATF. It seems to work as it should, but the resistance is quite stout. When I push on it, it moves quite slowly, and I, like, ain't no light-weight.
Is it acceptable to be quite firm, or should I look for thinner fluid?
Gary (1939 3/4 ton JD pickup)
A good working shock is quite hard to move.
My Blog
Dave,
If that's the case, I think I have at least one good shock. Somewhat of a surprise after all these years. I will get into the others...soon...
Gary
I have been using ATF for 25 years in shocks with good results.
Good luck with the next shock!
My Blog
