1 members (texczech), 51 guests, and 2 robots.
Topics128,024
Posts1,055,395
Members48,422
#64358 08/14/2006 7:57 PM
will the crank out of a 47 work in a 51 block.I sean were the in side changed beteen 47 and 48 not sure what?
1951 Chevy 3100 Deluxe 5-window
Four generations and still not for sale!
More pictures in Photobucket
David
#64359 08/14/2006 8:17 PM
Are you wondering about the hand crank or the crank shaft?
I'm not sure about the crank shaft, but the hand crank should work.
#64360 08/14/2006 8:19 PM
The rods became narrower in 1948. If you use the 47 rods with the 47 crank I beleve it will work fine.
My Blog
#64361 08/14/2006 8:34 PM
I need a engine crank for my 51 block but Im not sure if the engine in there now is a 47 or 48 with out tearing down a good engine. maybe I can found a good crank out of 49 to 53 to besure.
Thank David
David
#64362 08/15/2006 2:02 AM
A 1948 and 49 216 will have a raised 2 inch diameter circle with 48 in the center of it between the distributor and the road draft tube. A 1950 will just have the circle with nothing in it.
You can also pull the starter and find the casting date behind it.
The casting number can help also.
My Blog
