| | | Forums66 Topics128,026 Posts1,055,409 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#64358 08/14/2006 7:57 PM | Joined: Jul 2006 Posts: 100 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 100 | will the crank out of a 47 work in a 51 block.I sean were the in side changed beteen 47 and 48 not sure what? | | |
#64359 08/14/2006 8:17 PM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Are you wondering about the hand crank or the crank shaft?
I'm not sure about the crank shaft, but the hand crank should work. | | |
#64360 08/14/2006 8:19 PM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The rods became narrower in 1948. If you use the 47 rods with the 47 crank I beleve it will work fine.
See the USA in your vintage Chevrolet! My Blog | | |
#64361 08/14/2006 8:34 PM | Joined: Jul 2006 Posts: 100 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 100 | I need a engine crank for my 51 block but Im not sure if the engine in there now is a 47 or 48 with out tearing down a good engine. maybe I can found a good crank out of 49 to 53 to besure. Thank David | | |
#64362 08/15/2006 2:02 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | A 1948 and 49 216 will have a raised 2 inch diameter circle with 48 in the center of it between the distributor and the road draft tube. A 1950 will just have the circle with nothing in it.
You can also pull the starter and find the casting date behind it.
The casting number can help also.
