3 members (Shardean, Ponchogl, dt235sd), 92 guests, and 3 robots.
Topics128,021
Posts1,055,349
Members48,420
#643432 05/04/2010 4:14 PM
I am running a 1973 3/4 ton 4x4 under my 53 GMChevy. I saw some nice looking wheels on craigslist from a late model Duramax. Has anyone tried wheels like these on earlier trucks? My hope is to find something with a greater backspace to move my front tires in an inch or two.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
The geometry of a front end is set up to put the load of the wheel directly under the inner/larger brng. When you start playing around with wheels you change this and start prying on the outer/small brng.If this is just a toy you can get by if it is a daily driver you are asking for more maintanence.
Wouldn't that affect be lessened with a 4x4 set-up? Both my axles are DANA.
1953 Chevrolet 3600
No. The wheel centerline will still be shifted in relation to the bearings. There's also potential issues with the tires rubbing the draglink due to the changed backspace, as well as the scrub radius being altered. Best would be to use wheels for the application of the chassis you're using.
As far as covering the tires, have you considered using 1.5 or 2 ton front fenders with a wider rear fender? I have seen guys do this on other trucks, and it looks pretty cool. Something you might consider.
Bill Burmeister
Quote
only in hindsight which is always 20:20. The truck is done with body and paint. I'm satisfied with the rear tire locations, but the fronts stick out a little and are rubbing my fenders under extreme conditions of turning into steep driveways. I think an inch on each side would fix it and two inches would make it look perfect.
1953 Chevrolet 3600
