0 members (),
46
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | I am running a 1973 3/4 ton 4x4 under my 53 GMChevy. I saw some nice looking wheels on craigslist from a late model Duramax. Has anyone tried wheels like these on earlier trucks? My hope is to find something with a greater backspace to move my front tires in an inch or two. | | | | | Joined: Apr 2010 Posts: 160 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 160 | The geometry of a front end is set up to put the load of the wheel directly under the inner/larger brng. When you start playing around with wheels you change this and start prying on the outer/small brng.If this is just a toy you can get by if it is a daily driver you are asking for more maintanence. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Wouldn't that affect be lessened with a 4x4 set-up? Both my axles are DANA. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | No. The wheel centerline will still be shifted in relation to the bearings. There's also potential issues with the tires rubbing the draglink due to the changed backspace, as well as the scrub radius being altered. Best would be to use wheels for the application of the chassis you're using. As far as covering the tires, have you considered using 1.5 or 2 ton front fenders with a wider rear fender? I have seen guys do this on other trucks, and it looks pretty cool. Something you might consider.
Bill Burmeister | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | have you considered using 1.5 or 2 ton front fenders with a wider rear fender? only in hindsight which is always 20:20. The truck is done with body and paint. I'm satisfied with the rear tire locations, but the fronts stick out a little and are rubbing my fenders under extreme conditions of turning into steep driveways. I think an inch on each side would fix it and two inches would make it look perfect. | | |
