5 members (rick46ia, elhippie64, Peggy M, JW51, 1955firstseries), 66 guests, and 2 robots.
Topics128,022
Posts1,055,361
Members48,420
#643439 05/04/2010 5:00 PM
I am filling my new brake lines and master cylinder with fluid and I was wondering if I need the engine running to bleed the brakes? It has a hydrovac brake boost and I didn't know if the boost aided in bleeding the brakes while the engine is running or if I simply pump the brakes with the engine cold. Thanks.
1946 2 Ton Flatbed
gatsby46 #643443 05/04/2010 5:22 PM
It shouldn't matter. the booster just makes braking easier for the driver it doesn't change the mechanics of it all.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Just a heads up there should be at least one bleeder on the hydro vac sometimes two.
Thanks guys! I will keep an eye out for the bleed screws on the hydrovac...
1946 2 Ton Flatbed
gatsby46 #643504 05/04/2010 9:03 PM
In newer trucks (Advance-Design years) the bleeding procedure for a hydrovac system is different from the bleeding procedure for a standard system. But, I do not think that the engine has to be running to bleed a hydrovac system .
tclederman #643692 05/05/2010 11:52 AM
I do not think that the engine has to be running.
no, it doesnt have to be running. while your bleeding to check the health of your hydravac disconnect the vac. line off the can. if brake fluid runs out then its leaking.
Thanks for the hydrovac bleed tip Tim! I'm working on them today.
1946 2 Ton Flatbed
