1 members (Hotrod Lincoln),
57
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#64337 08/13/2006 11:57 PM | Joined: Aug 2006 Posts: 11 Junior Member | | Junior Member Joined: Aug 2006 Posts: 11 | I'd love to know where to get a ring-and-pinion set to switch from 4:11 gears to 3:50 or 3:55 gears. Can you fine folks suggest a good supplier? How about an installer in the Carolinas?
"A 10-speed? No need... my pickup gets me where I please... a-chuggin' down the street..." -Jimmy Buffett
#64338 08/14/2006 12:19 AM | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | | | |
#64339 08/14/2006 1:11 AM | Joined: May 2004 Posts: 204 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 204 | Second that! Talk to Patrick's. He has the instructions for them and they will walk to through the install process. Not to mention they are Patricks design.
If you need help with the shims to set the ring to pinion mesh let us know. There are plenty of good pictures amongst the group here. | | |
#64340 08/14/2006 2:20 AM | Joined: Aug 2006 Posts: 11 Junior Member | | Junior Member Joined: Aug 2006 Posts: 11 | Thanks Greg-H and Chev235.... Looks like a decent set-up. Much appreciated.
#64341 08/14/2006 12:38 PM | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | also try www.randysringandpinion.com. his site also has a calculator to see what is proper for your use. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
#64342 08/14/2006 9:11 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It would also help if we knew what you are running. There are alternatives & limitations depending on the vintage. Welcome to the websight. Should we call you Bigred or Goofball. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
