3 members (Gdads51, Raymond HAYWOOD, IHPWR), 175 guests, and 2 robots.
Topics128,088
Posts1,055,993
Members48,430
#64337 08/13/2006 11:57 PM
Junior Member
Junior Member
I'd love to know where to get a ring-and-pinion set to switch from 4:11 gears to 3:50 or 3:55 gears. Can you fine folks suggest a good supplier? How about an installer in the Carolinas?
"A 10-speed? No need... my pickup gets me where I please... a-chuggin' down the street..." -Jimmy Buffett
Patrick's has all you need for this swap http://www.patricksantiquecars.com/index.htm
Second that! Talk to Patrick's. He has the instructions for them and they will walk to through the install process. Not to mention they are Patricks design.
If you need help with the shims to set the ring to pinion mesh let us know. There are plenty of good pictures amongst the group here.
Junior Member
Junior Member
Thanks Greg-H and Chev235.... Looks like a decent set-up. Much appreciated. grin
also try www.randysringandpinion.com. his site also has a calculator to see what is proper for your use. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Riding in the Passing Lane
It would also help if we knew what you are running. There are alternatives & limitations depending on the vintage. Welcome to the websight. Should we call you Bigred or Goofball.
1972 Chevy c10 Cheyenne Super
