| | | Forums66 Topics128,074 Posts1,055,913 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | Hi All
Do I need any kind of primer on the engine before I paint high temp engine paint or can I just spray directly engine paint? And for 235 6 cyl and bellhousing how much paint will I really need. I hate spray cans because some how I end up dripping not sure if that will happen with HVLP HF gun also. I am newbie to paint.
Any suggesstions please
Rgds., Ganesh | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | No primer, just a clean surface.
If you're not going to use rattle-cans the minimum quantity you can buy is a quart and that will be WAY more than you need. I used the Hirsch aerosol and it took one can. Don't scrimp, get a heavy coating.
BTW, No problem with the drips with that product. | | | | | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | | | |
