| | | Forums66 Topics128,077 Posts1,056,015 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 43 | Hello all , just bought a 51 GMC burb, with plenty of things to do , Firstly is it possible to get door keys made from the number stamped on the lock, all my keys are missing , im also after the chrome ring that that fits around the front park light secondhand will be good enougth thanks in advance
i dont mind getting older , i just dont want to grow up !!!
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I had an old locksmith key all my locks last year. He claimed to have all the GM keys, by number, between 400-500 different numbers. He says that if he had the number, he would get the correct key. This was for my '53 Chevy, I assume that GMC would be included. I just re-read your post, he needs the number that is in the stamped out part of the key, I don't think the lock number would help. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Yes, the number stamped on the door lock is the key code. And there were 1500 key codes, starting at 8000 and going to 9499. These same codes were used from 1935 to 1966 for all GM vehicles. It might be hard to find a locksmith with the code book in UK. I have one. PM me if you need info for your local locksmith.
You should post your parts wanted request in the proper forum. (swap meet) | | | | | Joined: Feb 2010 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 43 | OOOPs sorry about listing wants here it wont happen again, My lock number is 9234 i have tried several Uk locksmiths but they are unable to help me all telling me to try the USA , Can anyone give me a phone /email contact of a Locksmith in the USA who might be able to help me. thanks
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | hey cookie, you're unlikely to find anyone who could do it 'by the numbers', but Nick can likely make you a key - lots closer, I'll bet he'd fix you up  Bill | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You need a B-10 key cut to 442355.
| | | | | Joined: Sep 2008 Posts: 4 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 4 | If you send me the barrels I will cut you keys to the locks, that way you will be sure of the keys working, I am in Sussex, we can do this by post, here is my number, 01797 253754 or you can p.m. me regards Nick | | | | | Joined: Feb 2010 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 43 | Many thanks to you all , for the information , i will call Nick tommorrow to arrange getting a key cut , thanks again Lez
