6 members (Paul_WNC, Gdads51, Shardean, Greg_H, NorCal52Suburban, Waveski), 60 guests, and 6 robots.
Topics128,021
Posts1,055,357
Members48,420
#642932 05/03/2010 4:16 AM
I’d like to paint the timing ball white on the flywheel of my truck (56 Chevy, 235). Is there enough room to get close to the ball if I remove the floor starter? Trying to paint it through the little hole in the housing is a challenge. Just wondering if anyone else has a good method for doing this.
Thanks.
Mark
1956 Chevy 3200, 1/2 Ton, 235 CI
https://photos.app.goo.gl/TQQo1YnFjs3U7xB57
MarkT #642936 05/03/2010 4:22 AM
You might gain some room going through the starter hole, but just painting the pointer should suffuce for timing purposes. The ball should still show up fine with the timing light.
Bill Burmeister
LONGBOX55 #642950 05/03/2010 4:41 AM
I wasn't sure how much room I would get if I pulled the starter. I'll try just painting the pointer first and see if that helps. That would be the quick and easy way.
Thanks.
MarkT #642963 05/03/2010 5:21 AM
Removing the lower access cover under the bellhousing is easy, and you should get plenty of room on either side ofthe oil pan to reach what you need to reach. Enough to paint yor timing ball and even the other marks
1956 GMC 370 dump " 'Tater "
1970 VW Volksrod "the Black Bomber"
2007 Chevy Avalanche
2020 Jeep Cherokee Trailhawk,
2005 Harley Davidson FLHTCUI
I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things.
But thats just MY opinion!
:P
Freq2002 #642968 05/03/2010 5:33 AM
Thanks much. I'll check that out. It would be nice to get that clean.
MarkT #643041 05/03/2010 2:11 PM
Ex Hall Monitor
Ex Hall Monitor
Maybe things are different on a 235 but I had no problem at all painting the ball on my 216 without removing anything. There was plenty of room. If it's too crowded on the starter side there's a twin opening on the opposite side (at least there is on my 216).
Tiny #643176 05/03/2010 9:26 PM
Thanks everyone. I appreciate it.
Mark
