1 members (baldeagle),
93
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | I’d like to paint the timing ball white on the flywheel of my truck (56 Chevy, 235). Is there enough room to get close to the ball if I remove the floor starter? Trying to paint it through the little hole in the housing is a challenge. Just wondering if anyone else has a good method for doing this.
Thanks. Mark
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You might gain some room going through the starter hole, but just painting the pointer should suffuce for timing purposes. The ball should still show up fine with the timing light.
Bill Burmeister | | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | I wasn't sure how much room I would get if I pulled the starter. I'll try just painting the pointer first and see if that helps. That would be the quick and easy way.
Thanks. | | | | | Joined: Dec 2006 Posts: 720 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 720 | Removing the lower access cover under the bellhousing is easy, and you should get plenty of room on either side ofthe oil pan to reach what you need to reach. Enough to paint yor timing ball and even the other marks 1956 GMC 370 dump " 'Tater "1970 VW Volksrod "the Black Bomber" 2007 Chevy Avalanche 2020 Jeep Cherokee Trailhawk, 2005 Harley Davidson FLHTCUI I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things. But thats just MY opinion! :P
| | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | Thanks much. I'll check that out. It would be nice to get that clean. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Maybe things are different on a 235 but I had no problem at all painting the ball on my 216 without removing anything. There was plenty of room. If it's too crowded on the starter side there's a twin opening on the opposite side (at least there is on my 216).
| | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | Thanks everyone. I appreciate it.
Mark | | |
