| | | Forums66 Topics128,106 Posts1,056,217 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 19 New Guy | | New Guy Joined: Nov 2009 Posts: 19 | hello guys I have my exhaust manifold cleaned sandblasted and now i am putting it together again but i miss the bimetal spring on the heater valve/cold start valve . do i have to find a replacement ? or can i just do with out it ? what will be the effect can it damage something or reduce exhaust fumes or something ?
| | | | | Joined: Nov 2009 Posts: 19 New Guy | | New Guy Joined: Nov 2009 Posts: 19 | Hi again i forgot to tell it is a 1958 235 and if there is a lowbudget solution ? thanks aj | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | That spring controls the amount of heat to the intake and without it your engine will not start or run properly. You need to find a new one and install it. With all the scrap 235's floating around you will probably not have a problem finding one in Truck Parts Wanted or you might want to check with NAPA to see if they stock them... can't be too expensive.
At least that's my understanding. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | You can buy one from LMC for $30 HERE It's called a heat riser spring or thermo spring. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | Ok, now I am curious Tim, after looking at both parts did the listed years use both springs? I have replaced the heat riser spring on my 52 with a 56 235 in it. Where did the anti rattle spring fit in? | | | | | Joined: Nov 2009 Posts: 19 New Guy | | New Guy Joined: Nov 2009 Posts: 19 | | | |
