1 members (baldeagle), 158 guests, and 2 robots.
Topics128,110
Posts1,056,241
Members48,437
#643006 05/03/2010 11:50 AM
hello guys
I have my exhaust manifold cleaned sandblasted and now i am putting it together again but i miss the bimetal spring on the heater valve/cold start valve .
do i have to find a replacement ? or can i just do with out it ?
what will be the effect can it damage something or reduce exhaust fumes or something ?
Hi again i forgot to tell it is a 1958 235 and if there is a lowbudget solution ?
thanks
aj
That spring controls the amount of heat to the intake and without it your engine will not start or run properly. You need to find a new one and install it. With all the scrap 235's floating around you will probably not have a problem finding one in Truck Parts Wanted or you might want to check with NAPA to see if they stock them... can't be too expensive.
At least that's my understanding.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
You can buy one from LMC for $30 HERE It's called a heat riser spring or thermo spring.
Woody
Door Art Collection
Ok, now I am curious Tim, after looking at both parts did the listed years use both springs? I have replaced the heat riser spring on my 52 with a 56 235 in it. Where did the anti rattle spring fit in?
thanks guys
greetz
aj
