9 members (moparguy, Bill Hanlon, GRNHydra, Otto Skorzeny, mason86, klhansen, Gray_Ghost, mick53, Hawkman),
93
Mod | | | Forums66 Topics128,069 Posts1,055,886 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 24 | I located a 1967 283ci engine for my 67 truck w/ granny 4-spd. The truck is now equipped with a 1969 307 ci engine. Will the flywheel now bolted to the 307 work for the 283? I assume yes but would like to confirm.
Asking a parts person from Advance or Auto Zone just does not work well on old stuff
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Yes. It will fit & work fine. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2010 Posts: 436 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 436 | Only flywheel you really need to worry about is if you go to the small block 400cid. The 400 is externally balanced and the rest of the SBC's are internally balanced. The small block 400 flywheels can not be interchanged with any other small block chevy. | | |
